Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
Remove four 13.8mm screws from the back of the device using a Phillips #1 screwdriver.
Remove a single 4.8 mm screw with a Phillips #0 screwdriver and lift away the battery pack being careful of the wires.
Remove two 7.2 mm screws with a Phillips #0 screwdriver.
Slide off the spring.
Remove the single 7.5mm screw with a Phillips #0 screwdriver.
Lift up the black plastic piece.
Remove four 7.5mm screws with a Phillips #0 screwdriver.
Remove the two buttons, noting how wires are placed for reassembly.
Lift the button board up and away to clear room for lifting the motherboard.
Tilt the assembly up but being wary that it is still attached to the front panel.
To reassemble, align the two black lines together by moving the belt back and forth.
Once aligned reinsert the toothed slider at the exact point shown.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Good work !
Nice.
I did not see the black line in mine,
i opened the foil and glued it new together . Not so nice. :D
But it works.
