Inleiding
This guide required
Wat je nodig hebt
Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
Remove four 13.8mm screws from the back of the device using a Phillips #1 screwdriver.
To reassemble your device, follow these instructions in reverse order, skipping step 10 as the toothed slider has already been put in for proper alignment.
Één andere persoon heeft deze handleiding voltooid.
1Gids Commentaar
Good work !
Nice.
I did not see the black line in mine,
i opened the foil and glued it new together . Not so nice. :D
But it works.
