Inleiding
Standing lamps are pretty simple units with a very small number of components. I found this lamp next to the dumpster and found that a simple safety switch on the top of the lamp was not pressed down properly, forcing the lamp to be in the off position at all times. This guide shows the user where the safety switch is (possibly) located, and how to test if the problem with the lamp is the switch.
Gereedschap
Onderdelen
Geen onderdelen nodig.
Standard Standing or Upright Lamp that won't turn on.
Remove the cone-shaped top from the lamp, which most likely includes the metal grate covering the halogen lamp.
My lamp has 3 "indents" (red circle) that slide into paths on the cone (red square). To remove the cone, twist the cone in the clockwise direction (while viewing from the shaft side of the lamp).
Chances are, if you have the problem that this lamp had, the cone will already be loose or not connected to the lamp. The cone is what presses down on the safety switch.
You can test the safety switch (green circle) at this point. Plug the lamp in and while pushing the safety switch all the way down, click through the on settings on the side of the shaft.
If the lamp turns on while your pushing the safety switch in, and turns off when you let go, thats your problem!
You can put the cone back on *properly* so that the switch is pressed down while the cone is on, or use some tape (electrical or duct tape maybe?) to secure the switch down permanently.
If this was not your issue, then you may be able to fix it with the next steps.
Remove the screws in the mounting brackets that secure the glass cover.
Remove the halogen lamp and the screws securing the metal heat shield below the lamp.
It is unlikely, but the safety switch (red square) may be completely broken and not making contact. If you have a multimeter that can measure conduction, touch the metal contacts that the two wires are going to and press the switch in to see if it makes contact.
If the switch doesn't work, you can remove this from the unit and connect the two wires via a wire nut or solder (and some sort of wire insulator, like heat shrink).
9 andere personen hebben deze handleiding voltooid.
5 Opmerkingen
Very useful information.
I have a halogen floor lamp that turns on however the low setting doesn't work. It only works on the high setting.
Would I go about fixing it the same way?
Thanks for any help!
Boom worked like a charm !!!
