Inleiding
You may find that your fridge isn't getting cold, but the freezer is just fine. If the inside fan is running, you should feel cold air blowing in through the diffuser in the top left corner of the fridge. If not, either your defroster is broken and ice has built up, or the diffuser is broken.
On ours, the diffuser door motor pushes on a small, fragile tab on the diffuser door. The tab snapped off. Rather than purchase a new $80 assembly, I fixed it with a toothpick and super glue. This fix may or may not last forever, (worked for about 3 years), but even if you want to replace the diffuser, it'll help you keep your cool until the replacement comes.
Wat je nodig hebt
Unload the top three shelves of the fridge, and top two shelves of the freezer into cooler(s).
Mark the location of the shelves with a bit of tape. Then remove the shelves by tipping up the front edge, then lifting and pulling them towards you.
Close the fridge door and open the freezer door. There's an air chute in the top of the freezer that will be coming out, along with the rear air chute. Remove the pair of screws on the top chute using the 1/4" hex socket. The back chute will still be holding the top chute in place.
If you're assisting, you may notice the ice dispenser is right next to the back of the person leaning into the fridge. Unless it's a very hot day, try not to slip ice cubes down the shirt/shorts of your cohort.
There is a spring clip in each corner of the fridge duct. Gently push them towards the center of the opening, and then towards the fridge.
There are 4 clips but only 2 are shown in the picture. (I forgot to take a picture after removing the right angle duct, so just imagine it's gone and you can see the other two as well. Please take a picture and update this page.)
Close the freezer door and head to the fridge side. But first, if your helper dropped ice down the back of your shorts in the prior step, feel free to return the favor.
Now you can carry the little troublemaker over to better light. You might be able to reach in with your little finger and wiggle the diffuser door. If it slides open and closed freely, the door's tab has broken. If not, it's also possible the motor is kaput. (Someone please contribute diagnostics for that)
Now remove diffuser cover. It's held in place by 4 pairs of tabs. Squeeze each pair of tabs with needle nose pliers and gently lift that corner. After all the tabs release, you can lift off the cover. Don't tip the base or the door will fall out.
I only marked three tabs in the photo. If you can't find the fourth tab, then I know what you did with the beer that didn't fit in the cooler in step one!
Examine the door to see where you can reinforce it without interfering with the cam or making the door thicker. Glue the plastic tab back in place, using a piece of flat toothpick or scrap of plastic to reinforce it. Use super glue or epoxy. Do not use heat to set the epoxy - this plastic softens very easily.
In the picture, you can see the broken tab, and the bit of toothpick next to it.
14 andere personen hebben deze handleiding voltooid.
11 opmerkingen
It would be nice to be able to buy the plastic slider instead of repairing it, does anyone know where I can purchase the slider?
Through my own troubleshooting, I came to the conclusion that my diffuser was likely broken. After defrosting my refrigerator, the fridge section did get down to 34F but then went back to 50F. I figured the diffuser door was able to close, but not open again. I almost ordered a new diffuser, but then this post motivated me to try and fix the old one. My diffuser door was only broken in one place, so it was springy when I manually moved the door while assembled with a screw driver. I glued the broken door as recommended here. lubed the plastic guides and main sliding surface inside of the cam drive and it seems to be working great. I believe my worn lower fridge door hinge (which was cheap and easy to replace - there are two pieces and two screws - don't buy new screws) had cause a right door seal breach which over time caused a build up of moisture then ice in the diffuser. When the door is physically restrained by ice and the cam turns, the door breaks. I'll bet this is the most common problem w this unit.
Electrical tape won’t work in the Ice box and that’s all I can contribute.
THANK YOU for this post! I spent the better part of the day working on my kitchenaid fridge. I cleaned the condenser coils, removed a heavy layer of ice from the bottom of the freezer and cleaned out the drain pipe… and then still suffered the problem of cold air not coming into the fridge through the damper… sure enough, this is exactly the issue I had, right down to the way the plastic broke. Just reinstalled it, and am very hopeful that my superglue job will be sufficient to keep it functioning. Shame that this piece is so fragile…
Thanks! I
typically always pull something apart to attempt a fix. I must be getting lazy in my old age, but this post reinvigorated me to take it apart and fix, well at least until a new one comes in the mail. Ebay new $44, normally about $100 to $130. I didn’t have any crazy glue available so just a touch of epoxy should do it. Great fix to verify the diffuser is the problem either for the fix or verify to order replacement. You could always have a burned board if the motor shorted. I should have checked the resistance. Maybe when I get the new one I will repost. I would have like to seen the motor drive it, but it seems to a bit buffered or something. Maybe I will set a time lapse and close the door.
