Wat je nodig hebt
Do your printed papers have these or similar vertical black and yellow lines?
Then this is the tutorial for you to make them disappear
12 andere personen hebben deze handleiding voltooid.
7 opmerkingen
Michael I have a thick horizontal line that repeats as a Ghost image. Will this help fix it? I have tried cleaning the paper track and the rollers etc, with no such luck.
same here, if i print a blank page it has various horizontal shadows and looks dirty
My printer was many years practically only B&W because of awful colors. This trick helped to restore colors. Thank you!
Step 4: you can also clean the bottom (and not only the top) of the black glossy plastic: it was the root cause of my black lines
Tested with CLX-3185FW
Thanks
this will laso work for the samsunc clp-310(n,w) and the clp-315(n,w)
I have the same issue but with colored lines. Will this fix that too?
https://i.imgur.com/Dyqgr2n.jpg
What's the process for cleaning colored lines?
