Ga door naar hoofdinhoud
Repairing Samsung clx-3175 Colour Laser Printer Fix black vertical lines
Wat je nodig hebt
  1. Repairing Samsung clx-3175 Colour Laser Printer Fix black vertical lines, Repairing Samsung clx-3175 Colour Laser Printer Fix black vertical lines: stap 1, afbeelding 1 van 1
    • Do your printed papers have these or similar vertical black and yellow lines?
    • Then this is the tutorial for you to make them disappear
  2. Repairing Samsung clx-3175 Colour Laser Printer Fix black vertical lines: stap 2, afbeelding 1 van 2 Repairing Samsung clx-3175 Colour Laser Printer Fix black vertical lines: stap 2, afbeelding 2 van 2
    • Open the printer front and take everything out
    • Take out the toners
    • Take out the drum together with the waste bin
  3. Repairing Samsung clx-3175 Colour Laser Printer Fix black vertical lines: stap 3, afbeelding 1 van 1
    • Your printer should now look like in the image attached
    • Use a flashlight to see inside the printer
    • On the glossy black plastic you will see vertical lines of color which are the cause of your printers problem
  4. Repairing Samsung clx-3175 Colour Laser Printer Fix black vertical lines: stap 4, afbeelding 1 van 3 Repairing Samsung clx-3175 Colour Laser Printer Fix black vertical lines: stap 4, afbeelding 2 van 3 Repairing Samsung clx-3175 Colour Laser Printer Fix black vertical lines: stap 4, afbeelding 3 van 3
    • Use a small white paper and try to stick it into the top - like shown
    • Move it from left to right and drag it out again
    • You will see that it is pretty dirty afterwards
    • Do this multiple times and clean the black glossy plastic with a cotton cloth - be careful not to scratch it
  5. Repairing Samsung clx-3175 Colour Laser Printer Fix black vertical lines: stap 5, afbeelding 1 van 1
    • Close the printer again and print some pages
    • After the 2nd or 3rd the black vertical lines should be gone completely
    • Have fun - again!
Conclusie
12 andere personen hebben deze handleiding voltooid.
Michael Ionita
414 Reputatie
1 Handleiding geschreven
7 opmerkingen
Michael I have a thick horizontal line that repeats as a Ghost image. Will this help fix it? I have tried cleaning the paper track and the rollers etc, with no such luck.
garthnathaniel - Antwoord
same here, if i print a blank page it has various horizontal shadows and looks dirty
Kevin Voyson - Antwoord
My printer was many years practically only B&W because of awful colors. This trick helped to restore colors. Thank you!
visitor visitor - Antwoord
Step 4: you can also clean the bottom (and not only the top) of the black glossy plastic: it was the root cause of my black lines
Tested with CLX-3185FW
Thanks
Jean-Baptiste Beaufreton - Antwoord
this will laso work for the samsunc clp-310(n,w) and the clp-315(n,w)
thijs kunst - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 58
Altijd: 41,804
