Ga door naar hoofdinhoud
Repairing Samsung SPH-A640 Keypad Replacement
Wat je nodig hebt
  1. Repairing Samsung SPH-A640 Keypad Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Press and hold the “End” button until the phone powers off.
  2. Repairing Samsung SPH-A640 Keypad Replacement: stap 2, afbeelding 1 van 2 Repairing Samsung SPH-A640 Keypad Replacement: stap 2, afbeelding 2 van 2
    • Turn the phone over on its backside.
    • Remove the bottom cover by sliding it downward, and then remove the battery.
  3. Repairing Samsung SPH-A640 Keypad Replacement, Keypad: stap 3, afbeelding 1 van 1
    • Using a #00 Phillips screwdriver, remove four screws from the bottom half of the phone in the battery compartment. Place screws off to the side.
  4. Repairing Samsung SPH-A640 Keypad Replacement: stap 4, afbeelding 1 van 1
    • Using spudger, pry off back cover starting at the bottom corners and moving around the perimeter towards the hinge. Disengaging the clips near the hinge may require some force.
  5. Repairing Samsung SPH-A640 Keypad Replacement: stap 5, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Using tweezers, carefully remove buttons from both sides while removing back cover. Note the positions of the buttons. They must be returned to the proper positions.
  6. Repairing Samsung SPH-A640 Keypad Replacement: stap 6, afbeelding 1 van 1
    • Using spudger, disconnect electrical connector near the hinge.
  7. Repairing Samsung SPH-A640 Keypad Replacement: stap 7, afbeelding 1 van 1
    • Using flathead screwdriver, lift motherboard away and remove from phone.
  8. Repairing Samsung SPH-A640 Keypad Replacement: stap 8, afbeelding 1 van 1
    • Lift, remove and replace key pad.
Conclusie
Natasha
1 Reputatie
1 Handleiding geschreven
Ohio State, Team 1-2, Meza Spring 2014 Lid van Ohio State, Team 1-2, Meza Spring 2014
OSU-MEZA-S14S1G2
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 238
