Ga door naar hoofdinhoud
Revlon 473 Hair Dryer Switch Replacement
Wat je nodig hebt
  1. Revlon 473 Hair Dryer Switch Replacement, Shell: stap 1, afbeelding 1 van 1
    • Before disassembly, make sure that the device is unplugged.
    • Remove the two 17.83 mm black screws located on the handle.
  2. Revlon 473 Hair Dryer Switch Replacement: stap 2, afbeelding 1 van 1
    • Separate the shell from the main component.
    • Check to ensure each piece is free from debris.
  3. Revlon 473 Hair Dryer Switch Replacement: stap 3, afbeelding 1 van 3 Revlon 473 Hair Dryer Switch Replacement: stap 3, afbeelding 2 van 3 Revlon 473 Hair Dryer Switch Replacement: stap 3, afbeelding 3 van 3
    • Remove the casing from the heating element.
    • For reassembly, reattach the silver casing before the black cover.
  4. Revlon 473 Hair Dryer Switch Replacement, Switch: stap 4, afbeelding 1 van 1
    • Locate the two switches in the handle of the device.
  5. Revlon 473 Hair Dryer Switch Replacement: stap 5, afbeelding 1 van 1
    • Set the multimeter to 200 ACV.
  6. Revlon 473 Hair Dryer Switch Replacement: stap 6, afbeelding 1 van 1
    • Bring the probes toward each switch to test for continuity.
    • If the numbers on the multimeter continue to change, the circuit is closed and the switches are functioning.
    • If the meter stays at a set number, the circuit is open, and the switch needs to be replaced.
    • To replace a faulty switch, cut the wires and solder the wires back on to the new switch.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jessica Leyva
143 Reputatie
5 handleidingen geschreven
Cal Poly, Team 1-5, Propen Fall 2012 Lid van Cal Poly, Team 1-5, Propen Fall 2012
CPSU-PROPEN-F12S1G5
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 24
Altijd: 1,801
