Ga door naar hoofdinhoud
Repairing Quasar Microwave Fan
Wat je nodig hebt
  1. Repairing Quasar Microwave Fan, Disassembling Quasar Microwave Outer Cover: stap 1, afbeelding 1 van 1
    • Disconnect the power supply cord from the outlet.
  2. Repairing Quasar Microwave Fan: stap 2, afbeelding 1 van 2 Repairing Quasar Microwave Fan: stap 2, afbeelding 2 van 2
    • Remove the eight screws holding the wood-patterned cover to the microwave frame.
    • The first four screws are located on either side of the microwave front.
  3. Repairing Quasar Microwave Fan: stap 3, afbeelding 1 van 2 Repairing Quasar Microwave Fan: stap 3, afbeelding 2 van 2
    • Remove the additional four screws securing the wood-paneled case to the microwave frame.
  4. Repairing Quasar Microwave Fan: stap 4, afbeelding 1 van 3 Repairing Quasar Microwave Fan: stap 4, afbeelding 2 van 3 Repairing Quasar Microwave Fan: stap 4, afbeelding 3 van 3
    • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
    • Lift the case upward slowly until the case is free of the microwave.
  5. Repairing Quasar Microwave Fan, Repairing Quasar Microwave Fan: stap 5, afbeelding 1 van 2 Repairing Quasar Microwave Fan, Repairing Quasar Microwave Fan: stap 5, afbeelding 2 van 2
    • Locate the fan in the newly exposed interior.
    • Try spinning the fan with your finger. If it spins freely, the fan is not jammed.
    • If the fan does not spin freely, locate what is jamming the fan and remove it.
  6. Repairing Quasar Microwave Fan: stap 6, afbeelding 1 van 1
    • If the fan is not jammed yet still does not work, check that there are no disconnected wires, especially to the fan.
    • In order to work properly, there should be two wires going in and out of the fan. If you are missing either of these wires, locate the loose wire/s and connect them.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Melanie
107 Reputatie
2 handleidingen geschreven
Cal Poly, Team 2-12, Propen Fall 2012 Lid van Cal Poly, Team 2-12, Propen Fall 2012
CPSU-PROPEN-F12S2G12
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 1,500
