Ga door naar hoofdinhoud
Repairing Polaroid Sun 600 LMS Gear Train
Wat je nodig hebt
  1. Repairing Polaroid Sun 600 LMS Gear Train, Open film door: stap 1, afbeelding 1 van 2 Repairing Polaroid Sun 600 LMS Gear Train, Open film door: stap 1, afbeelding 2 van 2
    • Move film door slide on the left side of camera forward.
    • Pull film door open.
  2. Repairing Polaroid Sun 600 LMS Gear Train: stap 2, afbeelding 1 van 1
    • Locate small silver gear in top left corner of film bay.
  3. Repairing Polaroid Sun 600 LMS Gear Train: stap 3, afbeelding 1 van 1
    • Using a plastic opening tool, rotate gear downward until jam is cleared.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Matthew Lessig
63 Reputatie
3 handleidingen geschreven
Cal Poly, Team 3-18, Maness Winter 2010 Lid van Cal Poly, Team 3-18, Maness Winter 2010
CPSU-MANESS-W10S3G18
4 Leden
4 handleidingen geschreven
3 opmerkingen
How do you know if the jam is cleared ? I have the same camera but the problem with mine is the shutter button. Every time I press the red and black one it won't make the noise or spit out the film unless I go one button behind. Although when I do that the photo comes out black. I think the two buttons or supposed to be together so when you press the red and black button the one behind it moves in sync. I really need help on fixing it and I'm not sure if what I said made any sense but I need help.
Tiffany - Antwoord
I have this very same problem…You explained it perfectly, however, I can’t figure out how to fix it. Please someone help us!
Jordan Brown -
Currently trying to fix it but after the steps it isn’t working. How do I know how many times to turn the gear?
Eleanor Murphy - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 36
Altijd: 9,061
