Ga door naar hoofdinhoud
Repairing Oster 6344 Toaster Lever
Wat je nodig hebt
  1. Repairing Oster 6344 Toaster Lever, Repairing Oster 6344 Toaster Lever: stap 1, afbeelding 1 van 3 Repairing Oster 6344 Toaster Lever, Repairing Oster 6344 Toaster Lever: stap 1, afbeelding 2 van 3 Repairing Oster 6344 Toaster Lever, Repairing Oster 6344 Toaster Lever: stap 1, afbeelding 3 van 3
    • Assure the toaster is unplugged.
  2. Repairing Oster 6344 Toaster Lever: stap 2, afbeelding 1 van 2 Repairing Oster 6344 Toaster Lever: stap 2, afbeelding 2 van 2
    • Look down into the bread slots and assure that the metal tongues are not bent or crooked.
    • If the metal tongues are bent use the pliers to straighten them.
    • Plug your toaster back in and test it to see if the lever stays down.
  3. Repairing Oster 6344 Toaster Lever: stap 5, afbeelding 1 van 1
    • (Optional): To clean the toaster, make sure it is unplugged, empty the crumb tray and then clean out all visible residue.
    • Note: Compressed air, wooden skewers, and slightly damp, lint free cloths are most helpful when cleaning your toaster.
    • Be sure that the toaster is completely dry from cleaning before you reassemble it.
Conclusie
Daniel
109 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 1,712
