Ga door naar hoofdinhoud
Repairing Minolta Dimage Xt Lens Cover
Wat je nodig hebt
  1. Repairing Minolta Dimage Xt Lens Cover, Casing: stap 1, afbeelding 1 van 3 Repairing Minolta Dimage Xt Lens Cover, Casing: stap 1, afbeelding 2 van 3 Repairing Minolta Dimage Xt Lens Cover, Casing: stap 1, afbeelding 3 van 3
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Repairing Minolta Dimage Xt Lens Cover: stap 2, afbeelding 1 van 3 Repairing Minolta Dimage Xt Lens Cover: stap 2, afbeelding 2 van 3 Repairing Minolta Dimage Xt Lens Cover: stap 2, afbeelding 3 van 3
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
  3. Repairing Minolta Dimage Xt Lens Cover, Lens Cover: stap 3, afbeelding 1 van 1
    • Place the internal electronics face-up. Look at the side with the flash turned towards you.
    • The lens cover is a small sheet of metal that rests directly infront of the lens when the camera is turned off.
    • Check to see if the spring action arm (what the yellow arrow is pointing to) is attached to the lens cover with the small knob in the corner (circled in yellow).
  4. Repairing Minolta Dimage Xt Lens Cover: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • If the arm is not attached (as shown in the previous), use tweezers to place the arm over the knob on the lens cover.
    • Inside the yellow circle, the arm is in the correct position.
Conclusie
Reassemble the casing by reversing steps 1 and 2.
Één andere persoon heeft deze handleiding voltooid.
Megan Milam
56 Reputatie
5 handleidingen geschreven
Clemson, Team 12-4, Benson Spring 2013 Lid van Clemson, Team 12-4, Benson Spring 2013
CLEM-BENSON-S13S12G4
3 Leden
14 handleidingen geschreven
1Gids Commentaar
In Bild 3 ist der gelbe Kreis falsch gesetzt: der kleine Knopf ist unten links an der Blende, wie in Bild 4 positioniert. hr
Hubert Rieping - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 24
Altijd: 1,478
