Inleiding
This guide explains the procedure that is necessary to repair a loose headphone jack. If you experience interrupted sound coming out of one headphone or sound coming only out of one headphone this guide may be the solution to your problem.
Wat je nodig hebt
Gently, insert a guitar pick (or a similar plastic pry tool) into the upper right corner of the Clip+ between the two case halves.
With the guitar pick inserted into the two case halves make your way around the edges of the case.
The plastic noses will come off easily.
To reassemble your device, follow these instructions in reverse order - of course without de-soldering.
15 andere personen hebben deze handleiding voltooid.
9 opmerkingen
Thanks a lot for this repair guide.
I always struggle when trying to open tiny plastic cases like this one, so it's alway good to see how many of those snap hooks you have to expect.
Opening the case was - as expected - pretty difficult, it took me about ~45 minutes or so. Re-soldering the pins was comparitively easy.
Worked exactly as described
I'm on my fourth Clip+. They never last more than 1.5 to 2 years, which I suppose is good value for the money, since I use mine almost constantly as a media player and my portable USB drive. One survived two drops into the pool but the battery finally gave out. Two others simply quit working, I think because the firmware got into an unrecoverable state. My fourth one is now having mechanical problems in the USB jack, but I think I can fix it with spare parts from the others. They can be taken apart if you are gentle. The guitar pick is a good idea.
It's a shame that the mechanical parts of this player are underdesigned. Mine have all had the headphone jack start to fail, to stop retaining the plug. The USB interface also gets stubborn from time to time, file transfers often slow way down to the point of locking up the host computer too. I've never understood that.
Have my second running with Rockbox since over 5 years. The first one had a hardware defect after a few months and got replaced by Sansa. Am now looking at replacing the battery.
dawg -
This is all new to me...so I need more info. Like - what soldering points - where? Isn't everything soldered to the board? I do jewelry work, so the actual soldering should not be a problem. More pictures would be very helpful for me, as well. I want to be able to fix this mp3 player...battery is still good, and plenty of room for more stuff. New earphones didn't help, so it must be in the player. Thanks.
@imhadit : Check the picture in step 3 (the one with the bigger detail). It’s the big black block that the green “arrow” is pointing to in upper right corner. When you check closely, you can see 3 small balls of new solder there (one on the left side of the black block, two on the right side). Those are the metal plates from the jack hole where the headphones go (you can see the metal inside the headphones hole and follow where they go on the motherboard)
What kind of soldering tool would you recommend? I tried repairing mine but I overdid it and now there’s a slight background hiss. I want to do it right when I have to fix the new one.
Merci pour votre astuce , j'ai ouvert facilement le Sansa Clip + pour changer la batterie, en moins de 2 minutes avec un outils en plastique bleu pour ouvrir les téléphone portable. j'ai commencé dans l'angle là ou il y a l'entrée jack 3.5.
la batterie est une 323036. (ou BAK 323036P)
32 pour 3,2 mm d’épaisseur, 30 pour 30 mm de large et 36 pour 36 mm de long. Avec 290mAh.ou 300mAh
[url=https://imgbb.com/][img]https://i.ibb.co/XkmZTjF/Capture-d-cran-...[/img][/url]
