Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Gearchiveerd
Gearchiveerde handleiding
Deze handleiding wordt enkel nog bijgehouden voor historische doeleinden. Gebruik de laatste versie van deze gids om uw reparatie uit te voeren.
Gearchiveerd
  1. Pry off back plastic, starting at the gap provided at the bottom of the phone. A spudger can be used to make this easier. Pry off back plastic, starting at the gap provided at the bottom of the phone. A spudger can be used to make this easier. Pry off back plastic, starting at the gap provided at the bottom of the phone. A spudger can be used to make this easier.
    • Pry off back plastic, starting at the gap provided at the bottom of the phone. A spudger can be used to make this easier.
  2. Remove battery, prying from the provided gap at the upper-right corner of the battery Remove battery, prying from the provided gap at the upper-right corner of the battery
    • Remove battery, prying from the provided gap at the upper-right corner of the battery
  3. Depress MicroSD to eject it from the side of the case. Depress MicroSD to eject it from the side of the case.
    • Depress MicroSD to eject it from the side of the case.
  4. De essentiële toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  5. Remove 4 corner screws, you may have to remove a "VOID" sticker from one of the screw heads. Remove 4 corner screws, you may have to remove a "VOID" sticker from one of the screw heads. Remove 4 corner screws, you may have to remove a "VOID" sticker from one of the screw heads.
    • Remove 4 corner screws, you may have to remove a "VOID" sticker from one of the screw heads.
  6. Using a spudger, unclip the nine clips holding the back panel to the front panel, highlighted in included pictures. Start at the top, and work clockwise, being careful not to break the clips. There are, 1, 3, 2, and 3 clips on each side, respectively.
    • Using a spudger, unclip the nine clips holding the back panel to the front panel, highlighted in included pictures.
    • Start at the top, and work clockwise, being careful not to break the clips.
    • There are, 1, 3, 2, and 3 clips on each side, respectively.
    • After the clips are disengaged, there are no cables holding the back panel in place.
  7. Use your spudger to release the remaining clips, disconnecting the ribbon cables from the logic board.
    • Use your spudger to release the remaining clips, disconnecting the ribbon cables from the logic board.
  8. Remove 2 Phillips Screws holding the logic board to the front panel. Gently lift the logic board off the front panel.
    • Remove 2 Phillips Screws holding the logic board to the front panel.
    • Gently lift the logic board off the front panel.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Mobile Rapid Response Unit
1.941 Reputatie
6 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 3,889
