Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Pry off back plastic, starting at the gap provided at the bottom of the phone. A spudger can be used to make this easier.
Remove battery, prying from the provided gap at the upper-right corner of the battery
Depress MicroSD to eject it from the side of the case.
Remove 4 corner screws, you may have to remove a "VOID" sticker from one of the screw heads.
Using a spudger, unclip the nine clips holding the back panel to the front panel, highlighted in included pictures.
Start at the top, and work clockwise, being careful not to break the clips.
There are, 1, 3, 2, and 3 clips on each side, respectively.
After the clips are disengaged, there are no cables holding the back panel in place.
Use your spudger to release the jaw clip holding the Optical Track Pad cable to the logic board.
Remove Optical Track Pad from logic board.
Use your spudger to release the remaining clips, disconnecting the ribbon cables from the logic board.
Remove 2 Phillips Screws holding the logic board to the front panel.
Gently lift the logic board off the front panel.
Remove the two phillips screws from the top of the LCD frame.
Use your spudger to pry the LCD out of the frame.
4 andere personen hebben deze handleiding voltooid.
