Ga door naar hoofdinhoud
How to Repair Frayed Shoelaces
Wat je nodig hebt
  1. How to Repair Frayed Shoelaces, How to Repair Frayed Shoelaces: stap 1, afbeelding 1 van 1
    • Cut of the excess frayed shoelace.
  2. How to Repair Frayed Shoelaces: stap 2, afbeelding 1 van 3 How to Repair Frayed Shoelaces: stap 2, afbeelding 2 van 3 How to Repair Frayed Shoelaces: stap 2, afbeelding 3 van 3
    • Slip the entire heat shrink tube over the frayed part of the lace.
    • Make sure to clump the frayed part of the lace together when inserting the tubing.
    • Do not cover too much of the lace that is not frayed with tubing as that could result in unwanted indents in the shoelace.
  3. How to Repair Frayed Shoelaces: stap 3, afbeelding 1 van 2 How to Repair Frayed Shoelaces: stap 3, afbeelding 2 van 2
    • After slipping the tube on, grab the scissors and trim the excess tubing to the length of your satisfaction.
    • Remember not to go beyond the frayed part of the lace with tubing.
  4. How to Repair Frayed Shoelaces: stap 4, afbeelding 1 van 3 How to Repair Frayed Shoelaces: stap 4, afbeelding 2 van 3 How to Repair Frayed Shoelaces: stap 4, afbeelding 3 van 3
    • Now use the lighter and heat the heat shrink tube, about an inch away from the lace, until the tube becomes compressed all the way around.
    • Make sure to heat the heat shrink tube all the way around, heating the entire tube
    • When heating, always keep moving the lighter all around and not staying on one part of the tube for too long.
  5. How to Repair Frayed Shoelaces: stap 5, afbeelding 1 van 1
    • Repeat these steps on all the other frayed shoelaces.
Conclusie
When the heat shrink tube is completely shrunk to appropriate size, you are finished. Repeat steps 1-4 depending on how many frayed laces are present.
14 andere personen hebben deze handleiding voltooid.
Anirudh Jain
605 Reputatie
1 Handleiding geschreven
Cal Poly, Team 28-6, Green Spring 2015 Lid van Cal Poly, Team 28-6, Green Spring 2015
CPSU-GREEN-S15S28G6
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 73
Altijd: 11,680
