Ga door naar hoofdinhoud
Replacing a Casio Exilim EX-Z850 Speaker
Wat je nodig hebt
  1. Replacing a Casio Exilim EX-Z850 Speaker, Speaker: stap 1, afbeelding 1 van 3 Replacing a Casio Exilim EX-Z850 Speaker, Speaker: stap 1, afbeelding 2 van 3 Replacing a Casio Exilim EX-Z850 Speaker, Speaker: stap 1, afbeelding 3 van 3
    • Remove the screws on both sides and the bottom of the camera with the Phillips #00 screwdriver.
    • The bottom screws are longer than the side screw.
  2. Replacing a Casio Exilim EX-Z850 Speaker: stap 2, afbeelding 1 van 1
    • Gently pry apart the rear casing from the body of the camera.
    • Do not pull the casing completely away from the camera or you will damage the ribbon securing the rear casing to the contents inside the camera.
  3. Replacing a Casio Exilim EX-Z850 Speaker: stap 3, afbeelding 1 van 2 Replacing a Casio Exilim EX-Z850 Speaker: stap 3, afbeelding 2 van 2
    • Use the tweezers to gently peel the ribbon from the contents inside of the camera, leaving it connected to the rear casing.
    • Set aside rear casing.
  4. Replacing a Casio Exilim EX-Z850 Speaker: stap 4, afbeelding 1 van 2 Replacing a Casio Exilim EX-Z850 Speaker: stap 4, afbeelding 2 van 2
    • Use the tweezers to pry the LCD screen from the frame.
    • The bottom of the LCD screen is attached to the frame by black tape.
  5. Replacing a Casio Exilim EX-Z850 Speaker: stap 5, afbeelding 1 van 2 Replacing a Casio Exilim EX-Z850 Speaker: stap 5, afbeelding 2 van 2
    • Use the tweezers to flip the LCD screen to the other side.
    • The LCD screen has a ribbon on the bottom of it that is connected to the contents inside of the camera, do not pull it apart.
  6. Replacing a Casio Exilim EX-Z850 Speaker: stap 6, afbeelding 1 van 2 Replacing a Casio Exilim EX-Z850 Speaker: stap 6, afbeelding 2 van 2
    • Pry the LCD casing from the tape that is underneath it and then flip it to the opposite side to expose the contents under it.
  7. Replacing a Casio Exilim EX-Z850 Speaker: stap 7, afbeelding 1 van 3 Replacing a Casio Exilim EX-Z850 Speaker: stap 7, afbeelding 2 van 3 Replacing a Casio Exilim EX-Z850 Speaker: stap 7, afbeelding 3 van 3
    • Use the tweezers to flip open the connector that is holding the ribbon connected to the LCD screen in place.
    • Remove the LCD screen with the ribbon from the camera.
  8. Replacing a Casio Exilim EX-Z850 Speaker: stap 8, afbeelding 1 van 2 Replacing a Casio Exilim EX-Z850 Speaker: stap 8, afbeelding 2 van 2
    • Remove the front casing from the body of the camera.
  9. Replacing a Casio Exilim EX-Z850 Speaker: stap 9, afbeelding 1 van 2 Replacing a Casio Exilim EX-Z850 Speaker: stap 9, afbeelding 2 van 2
    • Remove two screws on the side where the battery is located using the Phillips #00 screwdriver.
    • Pull the side casing so it becomes dislocated from the top of the camera frame.
  10. Replacing a Casio Exilim EX-Z850 Speaker: stap 10, afbeelding 1 van 2 Replacing a Casio Exilim EX-Z850 Speaker: stap 10, afbeelding 2 van 2
    • On the front of the camera, near the flash flip, there is a connector holding a ribbon. Remove the ribbon from the connector.
  11. Replacing a Casio Exilim EX-Z850 Speaker: stap 11, afbeelding 1 van 3 Replacing a Casio Exilim EX-Z850 Speaker: stap 11, afbeelding 2 van 3 Replacing a Casio Exilim EX-Z850 Speaker: stap 11, afbeelding 3 van 3
    • Carefully remove the L shaped frame from the camera by popping the frame off the bumps and tabs located at the bottom of the camera.
    • There is a yellow and orange wire soldered onto the camera. Be careful not to disconnect them.
    • The blue box is the speaker.
  12. Replacing a Casio Exilim EX-Z850 Speaker: stap 12, afbeelding 1 van 1
    • Use the tweezers to remove the speaker.
Conclusie
Christian
320 Reputatie
3 handleidingen geschreven
Cal Poly, Team 4-38, Regan Winter 2011 Lid van Cal Poly, Team 4-38, Regan Winter 2011
CPSU-REGAN-W11S4G38
4 Leden
13 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 14
Altijd: 2,678
