Ga door naar hoofdinhoud
Repairing Buttons on Casio fx-300ES Calculator
Wat je nodig hebt
  1. Repairing Buttons on Casio fx-300ES Calculator, Calculator: stap 1, afbeelding 1 van 2 Repairing Buttons on Casio fx-300ES Calculator, Calculator: stap 1, afbeelding 2 van 2
    • Remove the six 5 mm screws on the back of the calculator.
  2. Repairing Buttons on Casio fx-300ES Calculator: stap 2, afbeelding 1 van 2 Repairing Buttons on Casio fx-300ES Calculator: stap 2, afbeelding 2 van 2
    • Carefully remove the back plate to reveal the circuit board and the battery.
  3. Repairing Buttons on Casio fx-300ES Calculator: stap 3, afbeelding 1 van 3 Repairing Buttons on Casio fx-300ES Calculator: stap 3, afbeelding 2 van 3 Repairing Buttons on Casio fx-300ES Calculator: stap 3, afbeelding 3 van 3
    • Remove the four 4 mm screws from the circuit board.
  4. Repairing Buttons on Casio fx-300ES Calculator: stap 4, afbeelding 1 van 1
    • Be aware of the placement of the blue, black, red, and yellow wires because they will fall out when the next step is taken.
  5. Repairing Buttons on Casio fx-300ES Calculator: stap 5, afbeelding 1 van 3 Repairing Buttons on Casio fx-300ES Calculator: stap 5, afbeelding 2 van 3 Repairing Buttons on Casio fx-300ES Calculator: stap 5, afbeelding 3 van 3
    • Carefully lift the circuit board while leaving the grey rubber piece face down.
    • Simply flip the circuit board and the screen over but do not remove them fully.
    • Make sure the calculator is face down.
    • Buttons are loose do not flip calculator over.
  6. Repairing Buttons on Casio fx-300ES Calculator: stap 6, afbeelding 1 van 3 Repairing Buttons on Casio fx-300ES Calculator: stap 6, afbeelding 2 van 3 Repairing Buttons on Casio fx-300ES Calculator: stap 6, afbeelding 3 van 3
    • Now lift the grey rubber piece off to reveal the individual buttons.
    • Buttons are loose make sure they do not come off with the rubber piece.
  7. Repairing Buttons on Casio fx-300ES Calculator: stap 7, afbeelding 1 van 3 Repairing Buttons on Casio fx-300ES Calculator: stap 7, afbeelding 2 van 3 Repairing Buttons on Casio fx-300ES Calculator: stap 7, afbeelding 3 van 3
    • To remove the buttons you can use your screwdriver and lightly flip them out of their individual spaces.
    • You can now access all the buttons and make any alterations needed.
  8. Repairing Buttons on Casio fx-300ES Calculator: stap 8, afbeelding 1 van 1
    • Refer to this picture if any buttons get misplaced or fall out.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Daniel Riedeman
192 Reputatie
1 Handleiding geschreven
Cal Poly, Team 28-2, Green Spring 2015 Lid van Cal Poly, Team 28-2, Green Spring 2015
CPSU-GREEN-S15S28G2
4 Leden
2 handleidingen geschreven
3 opmerkingen
Great photos make sure to replace the stock photos with those you take. Maybe retake photos with white background.
Kathryn Webb - Antwoord
my answer key button not working. when i press button it shows the X10 so what can i do plzz give tips for repairing
ayush shukla - Antwoord
Halp my board is stuck to the front plate sith super glue from previous owner.
[deleted] - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 56
Afgelopen 30 dagen: 205
Altijd: 22,912
