Ga door naar hoofdinhoud
Repairing Bose On-Ear headphones Shorted Right earphone
Wat je nodig hebt
  1. Repairing Bose On-Ear headphones Shorted Right earphone, Repairing Bose On-Ear headphones Shorted Right earphone: stap 1, afbeelding 1 van 2 Repairing Bose On-Ear headphones Shorted Right earphone, Repairing Bose On-Ear headphones Shorted Right earphone: stap 1, afbeelding 2 van 2
    • To repair a short in the wires, the head band has two screws, just above the headphones cups.
  2. Repairing Bose On-Ear headphones Shorted Right earphone: stap 2, afbeelding 1 van 2 Repairing Bose On-Ear headphones Shorted Right earphone: stap 2, afbeelding 2 van 2
    • After removing the two small screws, try closing the headband to it's shortest position. The outer panel will pop out toward the bottom edge.
    • You can then slide the panel out from under the collar. The collar may slide out of place while working, but can easily be slid back during re-assembly.
  3. Repairing Bose On-Ear headphones Shorted Right earphone: stap 3, afbeelding 1 van 2 Repairing Bose On-Ear headphones Shorted Right earphone: stap 3, afbeelding 2 van 2
    • After inspecting the wire inside, you may notice cracks in the corners were the wires bend when the headphones are folded. I cut a thin strip of electrical tape to use as reinforcement.
    • After sliding the collar up, you can extend the wire, giving you better access for wrapping or replacing.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Designer Dan
274 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 5,119
