Ga door naar hoofdinhoud
Repairing Black Display on an Asus Transformer TF101
Wat je nodig hebt
  1. Repairing Black Display on an Asus Transformer TF101, Bezel: stap 1, afbeelding 1 van 2 Repairing Black Display on an Asus Transformer TF101, Bezel: stap 1, afbeelding 2 van 2
    • The first step is to remove two Small Torx Screws on the bottom. I don't know the size as I happened to have an unmarked Torx screwdriver nearby that happened to fit.
  2. Repairing Black Display on an Asus Transformer TF101: stap 2, afbeelding 1 van 2 Repairing Black Display on an Asus Transformer TF101: stap 2, afbeelding 2 van 2
    • I used a metal opening tool to spearate the bezel from the front of the unit. Once I had it separated in one area it was relatively easy to spread it using my fingertip. I then worked around the bezel until it popped off.
  3. Repairing Black Display on an Asus Transformer TF101: stap 3, afbeelding 1 van 1
    • There are four screws to remove behind the bezel. I never got a good picture of the screws but two are indicated here and the other two are in a similar location but just out of the picture.
Conclusie
14 andere personen hebben deze handleiding voltooid.
Rene Jeddore
1.357 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 8,775
