Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
If you drop your keyboard at the upper right corner, your power button might get stuck and the keyboard will not work any longer.
This is a short guide which will show you an easy way to get it working again!
Wat je nodig hebt
Cut away the dented aluminum with your cutting knife. It's a little bit tricky and you have to use some force to cut it, but it will work.
Please be carefull with the knife! You can cut into your thumb very easily!
Once the aluminum that was holding the button in is cut away, your device is repaired. No reassembly is necessary.
56 andere personen hebben deze handleiding voltooid.
26 opmerkingen
This worked for me. Be Careful. I made it worse initially because the inside edge became rough with my hacking away. I ended up smoothing the edge with a stainless steel cuticle pusher. Also: Constantly blow the scrapings away so they don't get caught between the button and the edge.
Thanks for this idea. It worked great for me and saved the keyboard. My first idea was to try to fully disassemble the keyboard so I could bend the piece back out with pliers after removing the button. I probably would've destroyed the keyboard without fixing it without this simple idea.
It worked for me. Took an hour or so to carefully cut the alumunium around the button. It took quite long because I have a crappy cutter that will easily snapped its sharp point.
Eventually the click was starting to work. Didn't manage to cut deeper so the whole assembly is still stuck.
It worked! The dent is pressing the power button making it unmovable. Its was on that state until I changed batteries. Now scratched and dented but working. Apple design flaw.
