Ga door naar hoofdinhoud
Repairing AcuRite Intelli-Time Alarm Clock Unresponsive Buttons
Wat je nodig hebt
  1. Repairing AcuRite Intelli-Time Alarm Clock Unresponsive Buttons, Opening the Device: stap 1, afbeelding 1 van 1
    • Flip device upside down and remove the 4 foam pads at each corner.
    • Remove the 4 screws using a Philips Screwdriver.
    • Gently lift the case off of the body and set down in a safe place.
    • Unscrew Circuit board attached to the top of the case with the one screw in the center. Be careful not to strip the screw/break the circuit board.
  2. Repairing AcuRite Intelli-Time Alarm Clock Unresponsive Buttons: stap 5, afbeelding 1 van 1
    • Make sure all of the buttons are move-able.
    • Press buttons on circuit board while listening for a click.
    • If everything works on the inside, that might mean you need a new circuit board.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nicholas Roppolo
426 Reputatie
3 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 14
Altijd: 973
