Ga door naar hoofdinhoud
Repairing Acer Iconia B1-A71 Touch Screen Digitizer
Wat je nodig hebt
Video overzicht
  1. Repairing Acer Iconia B1-A71 Touch Screen Digitizer, Repairing Acer Iconia B1-A71 Touch Screen Digitizer: stap 1, afbeelding 1 van 3 Repairing Acer Iconia B1-A71 Touch Screen Digitizer, Repairing Acer Iconia B1-A71 Touch Screen Digitizer: stap 1, afbeelding 2 van 3 Repairing Acer Iconia B1-A71 Touch Screen Digitizer, Repairing Acer Iconia B1-A71 Touch Screen Digitizer: stap 1, afbeelding 3 van 3
    • Because I can't switch-off the tablet, I'm using the reset button to do this.
    • Now, remove the back cover.
    • If you have a memory card inside, don't forget to remove it!
  2. Repairing Acer Iconia B1-A71 Touch Screen Digitizer: stap 2, afbeelding 1 van 3 Repairing Acer Iconia B1-A71 Touch Screen Digitizer: stap 2, afbeelding 2 van 3 Repairing Acer Iconia B1-A71 Touch Screen Digitizer: stap 2, afbeelding 3 van 3
    They seem to have become aware of the problem at some point. My B1-A71 which was sent in for warranty a couple times has an additional green rubber square kind of thing holding the clip in tight, I notice your pictures don't have this.
    Emil Carr - Antwoord
Conclusie
15 andere personen hebben deze handleiding voltooid.
ZFix
191.182 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.519 handleidingen geschreven
14 opmerkingen
Thanks.. it worked for my tab... Great...
pandawa - Antwoord
s'il vous plait vous pouvez m'aider j'ai un problème avec mon Acer B1. problème de démarrage qu'on j'allume il y'a juste Acer qui s'affiche j'ai essayer d'aller en mode recovery (SD IMAGE UPDATE MODE) mais une fois que je clique dessus ça se bloque s'il vous plait besoin de votre aide
omy - Antwoord
If you have a memory card inside, remove it. If you have same problem again, you have a problem with Android OS or a hardware problem.
ZFix -
Great i thought i cannot use my acer anymore, but know its worked thx for the solutions.
Andri Sagita - Antwoord
Thanks for the info. I fixed my tablet before by using the steps. But, I had the same problem again. I tried to fix it again but it's not wrking. So how to fix the problem with Android OS or hardware problem? Cheers.
rinayaya - Antwoord
It didn't work... I tried rebooting, restarting and taking out the flex cable and putting it back in. Any more suggestions?
Liam Best - Antwoord
Yes, I applied this method and its working now. Thank you for your support
Thank you for your sharing
I'm writing from Turkey ,
Greetings.
Miralge
Birx - Antwoord
Hey!!!!! 6 meses sin usar mi tablet y batallando para corregir el problema y me.encuenteo con ustedes!!!!! Merecen las graciassssssssss thank you colombia
fernneyrueda2014 - Antwoord
thank you very much... my device is working now.... i'm from PHILIPPINES...
rosario bembo - Antwoord
thanks, took 2 minutes and now working like new!
cedon - Antwoord
excelente, arregle mi tablet por tu video, fabuloso!!!
mc.thinkpad - Antwoord
want my acer tablet fix screen jumping and letters typing
darious - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 39,297
