Inleiding
Very often problem with this model. In 60% it can be resolved only with reconnecting the Touchscreen flex / ribbon cable.
If this solution not helped you then you must to change your Touchscreen.
Acer Iconia B1-A71 Touchscreen Replacement
Please SUBSCRIBE to my channel ツ
Onderdelen
Geen onderdelen nodig.
Video overzicht
  1. Because I can't switch-off the tablet, I'm using the reset button to do this. Now, remove the back cover. If you have a memory card inside, don't forget to remove it!
    • Because I can't switch-off the tablet, I'm using the reset button to do this.
    • Now, remove the back cover.
    • If you have a memory card inside, don't forget to remove it!
  2. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
    Ooit iets gerepareerd? Je bent een genie.
    Deel je reparatie met #ImAGenius
    We zijn allemaal genieën
  3. Open the touchscreen flex cable connector and reconnect the cable. . Did you do it successfully?
Conclusie
15 andere personen hebben deze handleiding voltooid.
ZFix
162.554 Reputatie
304 handleidingen geschreven
Master Techs Lid van Master Techs
Community
280 Leden
784 handleidingen geschreven
Thanks.. it worked for my tab... Great...
pandawa - Antwoord
s'il vous plait vous pouvez m'aider j'ai un problème avec mon Acer B1. problème de démarrage qu'on j'allume il y'a juste Acer qui s'affiche j'ai essayer d'aller en mode recovery (SD IMAGE UPDATE MODE) mais une fois que je clique dessus ça se bloque s'il vous plait besoin de votre aide
omy - Antwoord
If you have a memory card inside, remove it. If you have same problem again, you have a problem with Android OS or a hardware problem.
ZFix -
Great i thought i cannot use my acer anymore, but know its worked thx for the solutions.
Andri Sagita - Antwoord
Thanks for the info. I fixed my tablet before by using the steps. But, I had the same problem again. I tried to fix it again but it's not wrking. So how to fix the problem with Android OS or hardware problem? Cheers.
rinayaya - Antwoord
Weergavestatistieken:
Afgelopen 24 Uren: 2
Afgelopen 7 Dagen: 10
Afgelopen 30 Dagen: 73
Altijd: 37,160
