Ga door naar hoofdinhoud
Repairing Acer Aspire 5100 Display Screen
Gearchiveerde handleiding
Deze handleiding wordt enkel nog bijgehouden voor historische doeleinden. Gebruik de laatste versie van deze gids om uw reparatie uit te voeren.
Wat je nodig hebt
  1. Repairing Acer Aspire 5100 Display Screen, Battery: stap 1, afbeelding 1 van 1
    • Make sure the laptop is turned off and unplugged.
    • Flip the laptop over so the audio jacks are facing you.
    • Unlock the battery by sliding the button (located above the battery) towards the outer edge of the computer. When you feel the battery release and pop up, gently pull the battery from its compartment.
    Vraag FixBot
  2. Repairing Acer Aspire 5100 Display Screen, Display Screen: stap 2, afbeelding 1 van 1
    • Flip the laptop back over and open it.
    Vraag FixBot
  3. Repairing Acer Aspire 5100 Display Screen: stap 3, afbeelding 1 van 1
    • Pry out the 4 screw covers with a dental pick or other small pointed tool, and remove the screws located beneath them.
    Vraag FixBot
  4. Repairing Acer Aspire 5100 Display Screen: stap 4, afbeelding 1 van 2 Repairing Acer Aspire 5100 Display Screen: stap 4, afbeelding 2 van 2
    • Use a plastic spudger to carefully pry the front bezel off.
    • The bezel will tend to "snap" off little by little, as you work around it, don't be afraid to use a little force.
    Vraag FixBot
  5. Repairing Acer Aspire 5100 Display Screen: stap 5, afbeelding 1 van 1
    • Now remove the top cover by unscrewing the two Phillips #0 screws found at the bottom of the panel.
    • You are removing the cover behind the LCD, not the LCD screen. The two screws are the only thing holding it so carefully support it so it does not pull on and damage any cables.
    Vraag FixBot
  6. Repairing Acer Aspire 5100 Display Screen: stap 6, afbeelding 1 van 1
    • Unplug the display data cable attached to the back of the LCD.
    • Do not touch this area,it destroys the backlight!
    Vraag FixBot
  7. Repairing Acer Aspire 5100 Display Screen: stap 7, afbeelding 1 van 1
    • Finally, remove the LCD screen by unscrewing the six screws connecting the LCD panel to the side frame.
    Vraag FixBot
Conclusie
3 andere personen hebben deze handleiding voltooid.
iDeleted
2.101 Reputatie
39 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 44
Altijd: 4,384
