Ga door naar hoofdinhoud
Thrustmaster T3PM RJ12 main cable Replacement
Wat je nodig hebt
  1. Thrustmaster T3PM RJ12 main cable Replacement, Disconnect the pedal heads: stap 1, afbeelding 1 van 2 Thrustmaster T3PM RJ12 main cable Replacement, Disconnect the pedal heads: stap 1, afbeelding 2 van 2
    • Unscrew all 6 screws from the pedal heads
    • Note the positioning of the pedal heads or take this opportunity to try out new position
  2. Thrustmaster T3PM RJ12 main cable Replacement, Remove screws from the bottom: stap 2, afbeelding 1 van 1
    • Use a Phillips driver to remove all screws at the bottom.
    • Keep track of each screw as to not loose it.
  3. Thrustmaster T3PM RJ12 main cable Replacement, Remove the top cover: stap 3, afbeelding 1 van 1
    • Remove the top cover and put it aside
  4. Thrustmaster T3PM RJ12 main cable Replacement, Disconnect the wires from pedal sensors: stap 4, afbeelding 1 van 3 Thrustmaster T3PM RJ12 main cable Replacement, Disconnect the wires from pedal sensors: stap 4, afbeelding 2 van 3 Thrustmaster T3PM RJ12 main cable Replacement, Disconnect the wires from pedal sensors: stap 4, afbeelding 3 van 3
    • Use the Tweezers to carefully remove the wires from the sensors
  5. Thrustmaster T3PM RJ12 main cable Replacement, Remove tape: stap 5, afbeelding 1 van 3 Thrustmaster T3PM RJ12 main cable Replacement, Remove tape: stap 5, afbeelding 2 van 3 Thrustmaster T3PM RJ12 main cable Replacement, Remove tape: stap 5, afbeelding 3 van 3
    • Lift the tape and remove the cable
    • You can keep the original tape, add new tape or use some other method to stabilize the cable.
  6. Thrustmaster T3PM RJ12 main cable Replacement, Replace the cable: stap 6, afbeelding 1 van 2 Thrustmaster T3PM RJ12 main cable Replacement, Replace the cable: stap 6, afbeelding 2 van 2
    • Carefully connect the wires of a new cable with the sensors
Conclusie
To reassemble your pedal set, follow these instructions in reverse order.
Formica Fusca
2.595 Reputatie
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 89
Altijd: 1,544
