Ga door naar hoofdinhoud
Nexus 9 Battery Replacement
Wat je nodig hebt
  1. Nexus 9 Battery Replacement, Rear Case: stap 1, afbeelding 1 van 3 Nexus 9 Battery Replacement, Rear Case: stap 1, afbeelding 2 van 3 Nexus 9 Battery Replacement, Rear Case: stap 1, afbeelding 3 van 3
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
  2. Nexus 9 Battery Replacement, Battery: stap 2, afbeelding 1 van 2 Nexus 9 Battery Replacement, Battery: stap 2, afbeelding 2 van 2
    • Carefully peel up the copper shielding with your fingers.
    • Before fully removing the copper shielding, make sure that the blue antenna cable is out of the way of the copper tab.
  3. Nexus 9 Battery Replacement: stap 3, afbeelding 1 van 1
    • Using the spudger tool, carefully remove the bottom of the battery from it's location below the logic boards.
    • The battery is attached to the motherboard with some adhesive, so you may need an iOpener to loosen up the adhesive. Check out the iOpener guide for info on how to do it.
    • Do not pull the battery from the tablet yet, as it is still connected to the motherboard.
  4. Nexus 9 Battery Replacement: stap 4, afbeelding 1 van 1
    • Now remove the metal clip covering the battery's connector cable located above the top left of the battery with the spudger.
    • After the metal clip is wiggled free, the battery's connector cable can be easily removed by just gently tugging it free.
  5. Nexus 9 Battery Replacement: stap 5, afbeelding 1 van 1
    • The battery should now lift free of the tablet.
Conclusie
29 andere personen hebben deze handleiding voltooid.
Kelsey Rodriguez
874 Reputatie
2 handleidingen geschreven
Cal Poly, Team 19-11, Maness Winter 2015 Lid van Cal Poly, Team 19-11, Maness Winter 2015
CPSU-MANESS-W15S19G11
5 Leden
7 handleidingen geschreven
11 opmerkingen
There are no batteries available in on the internet!!!!!!!!!!!!!!
Michael James - Antwoord
Dang. I'm gonna check anyway
MrSavedby Grace - Antwoord
I could not get the clip back onto the board. Is it just to hold down the connector or is there some heatsinking going on?
Volpo - Antwoord
If anyone knows where I can buy a battery, please let me know! I called HTC because I couldn't find one locally or online, and they told me that because my device was originally manufactured in Hong-Kong (purchased by me directly from Amazon, not a re-seller), they would not be able to sell me a battery or even do a replacement; I would have to contact Hong-Kong directly and go through them. Seriously, HTC? At any rate, if anyone has information on where I can find a battery it would be much appreciated.
Tim Davie - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 27
Altijd: 29,622
