Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Video-instructies
Eindstreep
36 andere personen hebben deze handleiding voltooid.
ian mdx
7.912 Reputatie
17 handleidingen geschreven
Good video!!
Mandy - Antwoord
Good video!
I have a question though. What did you use to bull back the back partbof the phone at the end of the video? You simply heated the glue that was already there?
Mattia Rappuoli - Antwoord
Please answer, what is the glue you used in the video? Thanks.
tcatt - Antwoord
The glue used here is the B7000 glue, which can be found on this site under tools or from aliexpress.com.
However, it should be mentioned that it is not required to use other glue than the sticky tape than phone already has, unless you are serious about waterproofing. I removed 98% of all the sticky tape that was there hoping it would be easier to open later. Funny thing is that I still have to use heat lol. Hard to remove all that sticky.
lightmeupper - Antwoord
The tool to pull back the cover is Suction Handle
Something tells me it may work with a 40-50mm diameter suction cup from dollar store as well :-)
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 115
Altijd: 65,500
