Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the three screws running along the back edge of case cover.
Remove the two screws from each side of the case cover.
Grab edges of the cover with your hands. Pull outward slightly, then straight up.
Be sure case cover has been removed prior to back panel removal.
Remove 5 screws from panel, as shown.
Use flat-head screwdriver to push in square tabs, located on each side of the back panel.
Use caution, the edges are sharp.
Één andere persoon heeft deze handleiding voltooid.
