Ga door naar hoofdinhoud
Removing the Phone Keypad
Wat je nodig hebt
  1. Removing the Phone Keypad, Removing the Back Panel: stap 1, afbeelding 1 van 2 Removing the Phone Keypad, Removing the Back Panel: stap 1, afbeelding 2 van 2
    • Orient the phone so that the phone model and other descriptive information is facing upward.
    • Locate the two silver screws near the hinge where the battery is housed.
    • Remove the silver screws using a Phillips head #2 screwdriver.
  2. Removing the Phone Keypad: stap 2, afbeelding 1 van 3 Removing the Phone Keypad: stap 2, afbeelding 2 van 3 Removing the Phone Keypad: stap 2, afbeelding 3 van 3
    • Pull off the back panel of the phone.
    • Make sure you pull the cover off carefully in order to prevent damage to the back cover.
  3. Removing the Phone Keypad, Keypad: stap 3, afbeelding 1 van 2 Removing the Phone Keypad, Keypad: stap 3, afbeelding 2 van 2
    • Locate and unscrew the circled screw using a Philips head #2 screw driver or screw driver head.
  4. Removing the Phone Keypad: stap 4, afbeelding 1 van 1
    • Lift the motherboard away from the phone housing.
    • Be careful when lifting the motherboard. To prevent damage to the motherboard, gradually lift it from its place in the assembly.
  5. Removing the Phone Keypad: stap 5, afbeelding 1 van 2 Removing the Phone Keypad: stap 5, afbeelding 2 van 2
    • Now that the motherboard has been lifted out of place, the keypad can be accessed.
    • Using your fingers push the buttons from the the phone toward the lifted motherboard.
    • Remove the keypad from the assembly.
Conclusie
Elizabeth Kelly
501 Reputatie
5 handleidingen geschreven
Clemson, Team 15-1, Benson Fall 2012 Lid van Clemson, Team 15-1, Benson Fall 2012
CLEM-BENSON-F12S15G1
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 947
