Inleiding
You will learn how to remove scroll wheel from the wheel mount.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Hold the mouse so that the bottom is facing up.
Remove the single Phillips #1 screw from the bottom half of the mouse.
Locate the scroll wheel on the mouse.
Grab the scroll wheel with your thumb and index finger.
Gently lift up, to remove the scroll wheel from the mouse.
Locate the spring on the scroll wheel, and carefully remove the spring.
Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
Één commentaar
Thank you! The photographs with good resolution and correct lighting made everything clear and comprehencible.
