Ga door naar hoofdinhoud
Removing the HP Elitebook 6930p Hard Drive
Wat je nodig hebt
  1. Removing the HP Elitebook 6930p Hard Drive, Battery Removal: stap 1, afbeelding 1 van 3 Removing the HP Elitebook 6930p Hard Drive, Battery Removal: stap 1, afbeelding 2 van 3 Removing the HP Elitebook 6930p Hard Drive, Battery Removal: stap 1, afbeelding 3 van 3
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p Hard Drive, Hard Drive: stap 2, afbeelding 1 van 3 Removing the HP Elitebook 6930p Hard Drive, Hard Drive: stap 2, afbeelding 2 van 3 Removing the HP Elitebook 6930p Hard Drive, Hard Drive: stap 2, afbeelding 3 van 3
    • With the bottom of the laptop facing up and the front toward you locate and loosen the two M2.0×5.0 captive screws holding the hard drive bay cover closed.
    • Lift the left side of the bay cover and swing it up and to the right to remove it.
    • Loosen the M2.5×10.0 captive screw that holds the hard drive in.
    • Grasp the plastic tab and slide the hard drive to the right to disconnect it from the motherboard.
    • Lift the hard drive straight up and out of the laptop.
  3. Removing the HP Elitebook 6930p Hard Drive: stap 3, afbeelding 1 van 2 Removing the HP Elitebook 6930p Hard Drive: stap 3, afbeelding 2 van 2
    • To remove the hard drive from the bracket remove the two M3.0×4.0 screws from each side of the hard drive.
Conclusie
17 andere personen hebben deze handleiding voltooid.
Richdave
32.371 Reputatie
30 handleidingen geschreven
Master Techs Lid van Master Techs
Community
327 Leden
1.699 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 21
Altijd: 9,963
