Ga door naar hoofdinhoud
Removing the HP Compaq dx2000MT Optical (CD) Drive
Wat je nodig hebt
  1. Removing the HP Compaq dx2000MT Optical (CD) Drive, Removing the HP Compaq dx2000MT Case Doors: stap 1, afbeelding 1 van 1
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Removing the HP Compaq dx2000MT Optical (CD) Drive: stap 2, afbeelding 1 van 2 Removing the HP Compaq dx2000MT Optical (CD) Drive: stap 2, afbeelding 2 van 2
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Removing the HP Compaq dx2000MT Optical (CD) Drive: stap 3, afbeelding 1 van 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: stap 3, afbeelding 2 van 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: stap 3, afbeelding 3 van 3
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Removing the HP Compaq dx2000MT Optical (CD) Drive: stap 4, afbeelding 1 van 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: stap 4, afbeelding 2 van 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: stap 4, afbeelding 3 van 3
    • Once again, this may take considerable force.
  5. Removing the HP Compaq dx2000MT Optical (CD) Drive, Optical (CD) Drive: stap 5, afbeelding 1 van 3 Removing the HP Compaq dx2000MT Optical (CD) Drive, Optical (CD) Drive: stap 5, afbeelding 2 van 3 Removing the HP Compaq dx2000MT Optical (CD) Drive, Optical (CD) Drive: stap 5, afbeelding 3 van 3
    • Remove the IDE data cable and the power cable from the optical drive by pulling away from the drive.
  6. Removing the HP Compaq dx2000MT Optical (CD) Drive: stap 6, afbeelding 1 van 2 Removing the HP Compaq dx2000MT Optical (CD) Drive: stap 6, afbeelding 2 van 2
    • Remove the 2 Torx T15 screws holding the optical drive in place.
  7. Removing the HP Compaq dx2000MT Optical (CD) Drive: stap 7, afbeelding 1 van 2 Removing the HP Compaq dx2000MT Optical (CD) Drive: stap 7, afbeelding 2 van 2
    • Remove the other 2 Torx T15 screws holding the other side of the drive in place.
  8. Removing the HP Compaq dx2000MT Optical (CD) Drive: stap 8, afbeelding 1 van 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: stap 8, afbeelding 2 van 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: stap 8, afbeelding 3 van 3
    • Remove the optical drive by sliding it out the front of the device.
Conclusie
Logan Pace
2.251 Reputatie
9 handleidingen geschreven
Cal Poly, Team 17-16, Regan Fall 2011 Lid van Cal Poly, Team 17-16, Regan Fall 2011
CPSU-REGAN-F11S17G16
4 Leden
17 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 1,501
