Inleiding
This guide is base on the official service manual which I have attached to the device page and has been created using photos contained in other iFixit guides.
Onderdelen
Geen onderdelen nodig.
  1. Place the laptop upside down on a clean, flat surface. Locate the battery release button with the padlock symbol above it. Slide the battery release button towards the padlock symbol and hold it there.  Note that the button is spring loaded and will return if released.
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
      • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
    Ooit iets gerepareerd? Je bent een genie.
    Deel je reparatie met #ImAGenius
    We zijn allemaal genieën
  3. Place laptop upsid down on a clean flat work surface. Remove the Philips M2.5 x 8 mm screw Loosen the screw that holds the memory compartment closed
    • Place laptop upsid down on a clean flat work surface.
    • Remove the Philips M2.5 x 8 mm screw
    • Loosen the screw that holds the memory compartment closed
    • remove the memory module compartment cover
    • Press the Optical Drive release lever to the right and the optical drive should slide out of the case
Conclusie
Richdave
28.967 Reputatie
30 handleidingen geschreven
Master Techs Lid van Master Techs
Community
280 Leden
784 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 2
Altijd: 362
