Inleiding
This guide will show you how to remove the keyboard on your Dell 1150 laptop
Wat je nodig hebt
Place the laptop upside down on a clean, flat surface.
Locate the battery release button with the padlock symbol above it.
Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
Gently remove the battery from the side of the laptop.
Use a spudger to lift the notched right edge of the hinge cover, and pry it loose
Lift the hinge cover off and set aside
Één andere persoon heeft deze handleiding voltooid.
