Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Before removing the good feet, remove the failed feet first. These may come off without disassembly if they have fully failed.
After removing the damaged feet, remove the intact feet. Follow the disassembly guide for your specific Mac.
Gereedschap gebruikt in deze stap:iFixit Opening Picks (Set of 6)$4.99-
To remove the intact feet, score the internal plug. Once scored, remove the plug with a guitar pick.
After removing the inner plug, push the foot out with a spudger or screwdriver.
Gereedschap gebruikt in deze stap:Adhesive Cleanup Kit (Set of 12)$4.99-
If the adhesive ring remains, remove it first. Clean the chassis with denatured alcohol or adhesive cleaner.
After removing the old feet, install the new set onto the bottom cover.
Re-install the cover on the computer.
4 andere personen hebben deze handleiding voltooid.
