Ga door naar hoofdinhoud
Removing factory feet from a Mac Laptop (Non-Retina)
Wat je nodig hebt
  1. Gereedschap gebruikt in deze stap:
    Essential Electronics Toolkit
    $23.96
  2. Removing factory feet from a Mac Laptop (Non-Retina), Remove the bottom cover: stap 2, afbeelding 1 van 2 Removing factory feet from a Mac Laptop (Non-Retina), Remove the bottom cover: stap 2, afbeelding 2 van 2
    • I am using a 2011 13" MacBook Pro. Most machines are similar, but variations may exist.
    • If possible, disconnect the battery to protect your components once the bottom is removed.
    • Remove the bottom cover of your MacBook with the guide for your specific system.
  3. Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: stap 3, afbeelding 1 van 3 Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: stap 3, afbeelding 2 van 3 Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: stap 3, afbeelding 3 van 3
    • Before removing the good feet, remove the failed feet first. These may come off without disassembly if they have fully failed.
    • After removing the damaged feet, remove the intact feet. Follow the disassembly guide for your specific Mac.
  4. Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: stap 4, afbeelding 1 van 3 Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: stap 4, afbeelding 2 van 3 Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: stap 4, afbeelding 3 van 3
    iFixit Opening Picks (Set of 6)
    • To remove the intact feet, score the internal plug. Once scored, remove the plug with a guitar pick.
    • After removing the inner plug, push the foot out with a spudger or screwdriver.
  5. Removing factory feet from a Mac Laptop (Non-Retina), Install the new feet: stap 5, afbeelding 1 van 2 Removing factory feet from a Mac Laptop (Non-Retina), Install the new feet: stap 5, afbeelding 2 van 2
    Adhesive Cleanup Kit (Set of 12)
    $7.99
    • If the adhesive ring remains, remove it first. Clean the chassis with denatured alcohol or adhesive cleaner.
    • After removing the old feet, install the new set onto the bottom cover.
    • Re-install the cover on the computer.
Eindstreep
5 andere personen hebben deze handleiding voltooid.
Nick
98.282 Reputatie
62 handleidingen geschreven
Master Techs Lid van Master Techs
Community
329 Leden
1.453 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 71
Altijd: 5,752
