Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Grab the back of the calculator with one hand and the cover with the other.
Pull the cover off from one of the sides for easy removal.
Orientate the calculator with the top facing towards you.
Slide the locking tab,found on the top part of the calculator, to the unlock position.
"Locking Tab"
To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
Then with the front of the calculator facing down, pull up on the back cover.
The calculator should now be orientated with the front facing down, as shown in picture 2.
