Ga door naar hoofdinhoud
Removing Texas Instruments TI-92 Back Cover
  1. Removing Texas Instruments TI-92 Back Cover, Back Cover: stap 1, afbeelding 1 van 3 Removing Texas Instruments TI-92 Back Cover, Back Cover: stap 1, afbeelding 2 van 3 Removing Texas Instruments TI-92 Back Cover, Back Cover: stap 1, afbeelding 3 van 3
    • The first step to any repair operation is to remove the front cover.
    • Grab the back of the calculator with one hand and the cover with the other.
    • Pull the cover off from one of the sides for easy removal.
  2. Removing Texas Instruments TI-92 Back Cover: stap 2, afbeelding 1 van 2 Removing Texas Instruments TI-92 Back Cover: stap 2, afbeelding 2 van 2
    • Orientate the calculator with the top facing towards you.
    • Slide the locking tab,found on the top part of the calculator, to the unlock position.
  3. Removing Texas Instruments TI-92 Back Cover: stap 3, afbeelding 1 van 2 Removing Texas Instruments TI-92 Back Cover: stap 3, afbeelding 2 van 2
    • "Locking Tab"
    • To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
    • Then with the front of the calculator facing down, pull up on the back cover.
    • The calculator should now be orientated with the front facing down, as shown in picture 2.
Conclusie
Daniel Maldonado
240 Reputatie
9 handleidingen geschreven
Cal Poly, Team 15-51, Garner Spring 2010 Lid van Cal Poly, Team 15-51, Garner Spring 2010
CPSU-GARNER-S10S15G51
5 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 17
Altijd: 3,290
