Inleiding
Step-by-step guide to removing your phone's back plate.
Onderdelen
Geen onderdelen opgegeven.
  1. Flip phone to see back cover. Using either finger or spugder tool press button located  near the top of phone by the antenna.
    • Flip phone to see back cover.
    • Using either finger or spugder tool press button located near the top of phone by the antenna.
  2. Pry up back plate from phone to reveal battery. Push button near bottom of battery using either your finger of the spudger.  This will release the battery.
    • Pry up back plate from phone to reveal battery.
    • Push button near bottom of battery using either your finger of the spudger. This will release the battery.
  3. MacBook-reparatiesets voor batterijen
    Vanaf $69.99
    Buy Now
    Vanaf $69.99
    Buy Now
  4. Using a T6 Torx Screwdriver remove the four torxs on the back of the phone.
    • Using a T6 Torx Screwdriver remove the four torxs on the back of the phone.
  5. Simultaneously press indicated buttons on both sides of phone. Simultaneously press indicated buttons on both sides of phone.
    • Simultaneously press indicated buttons on both sides of phone.
  6. Separate back plate from the rest of phone.
    • Separate back plate from the rest of phone.
    • Make sure to not pull, there is a wire (circled on image) connecting the two plates.
Conclusie
Elizabeth OBrien
31 Reputatie
7 handleidingen geschreven
Cal Poly, Team 30-40, Garner Spring 2010 Lid van Cal Poly, Team 30-40, Garner Spring 2010
CPSU-GARNER-S10S30G40
4 Leden
14 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 4
Altijd: 3,196
