Ga door naar hoofdinhoud
Removing Minolta X-370 Lens Holder
Wat je nodig hebt
  1. Removing Minolta X-370 Lens Holder, Minolta X-370 Battery Replacement: stap 1, afbeelding 1 van 2 Removing Minolta X-370 Lens Holder, Minolta X-370 Battery Replacement: stap 1, afbeelding 2 van 2
    • Flip the camera so that the bottom is facing you.
    • Take a spare coin and unscrew the battery cover off.
  2. Removing Minolta X-370 Lens Holder: stap 2, afbeelding 1 van 1
    • Remove the batteries, making sure to note their proper alignment.
  3. Removing Minolta X-370 Lens Holder, Bottom Cover: stap 3, afbeelding 1 van 2 Removing Minolta X-370 Lens Holder, Bottom Cover: stap 3, afbeelding 2 van 2
    • Remove two 4.8mm screws.
    • Remove one 3.4mm screw.
    • Remove one 2.65mm screw.
    • Lift off the back cover.
  4. Removing Minolta X-370 Lens Holder: stap 4, afbeelding 1 van 1
    • Remove three 3.5mm screws.
    • Remove two 3.8mm screws.
    • Remove one 6.35mm screw.
    • Remove one 4mm screw. Lift off the disk.
    • Remove one 5.11mm screw.
  5. Removing Minolta X-370 Lens Holder: stap 5, afbeelding 1 van 1
    • Lift up the silver, metal piece
    • Please note that some internal pieces may come loose during this process.
  6. Removing Minolta X-370 Lens Holder, Lens Holder: stap 6, afbeelding 1 van 3 Removing Minolta X-370 Lens Holder, Lens Holder: stap 6, afbeelding 2 van 3 Removing Minolta X-370 Lens Holder, Lens Holder: stap 6, afbeelding 3 van 3
    • Remove four 4.45mm screws and remove the alignment ring.
    • Remove the interior metal ring and the black plastic ring. Pay attention to the spring's location.
    • Pay attention to the alignment of the interior metal ring and the black plastic ring.
  7. Removing Minolta X-370 Lens Holder: stap 7, afbeelding 1 van 3 Removing Minolta X-370 Lens Holder: stap 7, afbeelding 2 van 3 Removing Minolta X-370 Lens Holder: stap 7, afbeelding 3 van 3
    • Remove the two black stoppers.
    • Using the metal spudger, remove the two triangular hangers.
  8. Removing Minolta X-370 Lens Holder: stap 8, afbeelding 1 van 2 Removing Minolta X-370 Lens Holder: stap 8, afbeelding 2 van 2
    • Using the metal spudger, peel off the right leather cover.
    • Be careful not to tear the cover because you will need to use it again.
  9. Removing Minolta X-370 Lens Holder: stap 9, afbeelding 1 van 3 Removing Minolta X-370 Lens Holder: stap 9, afbeelding 2 van 3 Removing Minolta X-370 Lens Holder: stap 9, afbeelding 3 van 3
    • Use the metal spudger to remove both the grip cover and the left leather cover.
    • Be careful not to tear the covers because you will need to use them again.
  10. Removing Minolta X-370 Lens Holder: stap 10, afbeelding 1 van 2 Removing Minolta X-370 Lens Holder: stap 10, afbeelding 2 van 2
    • Remove two 5.3mm screws.
    • Remove one 2.35mm screws.
  11. Removing Minolta X-370 Lens Holder: stap 11, afbeelding 1 van 2 Removing Minolta X-370 Lens Holder: stap 11, afbeelding 2 van 2
    • Remove the left and right plastic covers.
  12. Removing Minolta X-370 Lens Holder: stap 12, afbeelding 1 van 3 Removing Minolta X-370 Lens Holder: stap 12, afbeelding 2 van 3 Removing Minolta X-370 Lens Holder: stap 12, afbeelding 3 van 3
    • Remove two 6.65mm screws.
    • Remove two 2.93mm screws.
    • Remove four 5.3mm screws.
    • Remove the black plastic lens holder.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Nick
525 Reputatie
4 handleidingen geschreven
Cal Poly, Team 8-7, Regan Spring 2011 Lid van Cal Poly, Team 8-7, Regan Spring 2011
CPSU-REGAN-S11S8G7
4 Leden
8 handleidingen geschreven
Één opmerking
I have Problems to assemble the new black plastic lens holder.
The space between camera Cup and the housing is very low.
Did someone have the same Problems ?
Klaus Kohlhas - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 7,201
