Inleiding
You will be removing some leather grips, which you will reuse, to access some screws. Be careful not to tear these grips.
Wat je nodig hebt
Flip the camera so that the bottom is facing you.
Take a spare coin and unscrew the battery cover off.
Remove two 4.8mm screws.
Remove one 3.4mm screw.
Remove one 2.65mm screw.
Lift off the back cover.
Remove four 4.45mm screws and remove the alignment ring.
Remove the interior metal ring and the black plastic ring. Pay attention to the spring's location.
4 andere personen hebben deze handleiding voltooid.
Één opmerking
I have Problems to assemble the new black plastic lens holder.
The space between camera Cup and the housing is very low.
Did someone have the same Problems ?
