Ga door naar hoofdinhoud
Inleiding
This is a very simple task, only requiring a screwdriver.
Onderdelen
Geen onderdelen opgegeven.
  1. Lift up the winding lever and rotate it clockwise to open the back film compartment. Lift up the winding lever and rotate it clockwise to open the back film compartment.
    • Lift up the winding lever and rotate it clockwise to open the back film compartment.
  2. Lift up the winding handle and remove one 3.85mm screw. Remove the film winding handle.
    • Lift up the winding handle and remove one 3.85mm screw.
    • Remove the film winding handle.
  3. Pull the film winder down until it comes free. Do not close the film compartment. The compartment will not open without the film winding lever installed properly.
    • Pull the film winder down until it comes free.
    • Do not close the film compartment. The compartment will not open without the film winding lever installed properly.
    The film wonder handle does not slide back up in place. There is something blocking the way so it will not slide back up in place. What do I do now?
    Richard Hood - Antwoord
Conclusie
Nick
525 Reputatie
4 handleidingen geschreven
Cal Poly, Team 8-7, Regan Spring 2011 Lid van Cal Poly, Team 8-7, Regan Spring 2011
CPSU-REGAN-S11S8G7
4 Leden
Één commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 24
Altijd: 11,298
