Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Flip the camera so that the bottom is facing you.
Take a spare coin and unscrew the battery cover off.
Remove the batteries, making sure to note their proper alignment.
Remove two 4.8mm screws.
Remove one 3.4mm screw.
Remove one 2.65mm screw.
Lift off the back cover.
Remove three 3.5mm screws.
Remove two 3.8mm screws.
Remove one 6.35mm screw.
Remove one 4mm screw. Lift off the disk.
Remove one 5.11mm screw.
3 andere personen hebben deze handleiding voltooid.
Één opmerking
good advice, will use, have multiple Minolta cameras to work with.
