Inleiding
Only requires removing a few screws. No special tools required.
Wat je nodig hebt
Flip the camera so that the bottom is facing you.
Take a spare coin and unscrew the battery cover off.
Remove the batteries, making sure to note their proper alignment.
Hi just checking which type of batteries are required? You have two types listed, the SR44/LR44 (I understand those are the same types of batteries) then the CR-1 / 3 /3N 3V battery? How many batteries do I need and which type will I need? thanks!
Remove two 4.8mm screws.
Remove one 3.4mm screw.
Remove one 2.65mm screw.
Lift off the back cover.
3 andere personen hebben deze handleiding voltooid.
Één opmerking
good advice, will use, have multiple Minolta cameras to work with.
