Ga door naar hoofdinhoud
Removing Minolta X-370 Bottom Cover
Wat je nodig hebt
  1. Removing Minolta X-370 Bottom Cover, Minolta X-370 Battery Replacement: stap 1, afbeelding 1 van 2 Removing Minolta X-370 Bottom Cover, Minolta X-370 Battery Replacement: stap 1, afbeelding 2 van 2
    • Flip the camera so that the bottom is facing you.
    • Take a spare coin and unscrew the battery cover off.
  2. Removing Minolta X-370 Bottom Cover: stap 2, afbeelding 1 van 1
    • Remove the batteries, making sure to note their proper alignment.
    Hi just checking which type of batteries are required? You have two types listed, the SR44/LR44 (I understand those are the same types of batteries) then the CR-1 / 3 /3N 3V battery? How many batteries do I need and which type will I need? thanks!
    Juliette Perry-Dumarquez - Antwoord
  3. Removing Minolta X-370 Bottom Cover, Bottom Cover: stap 3, afbeelding 1 van 2 Removing Minolta X-370 Bottom Cover, Bottom Cover: stap 3, afbeelding 2 van 2
    • Remove two 4.8mm screws.
    • Remove one 3.4mm screw.
    • Remove one 2.65mm screw.
    • Lift off the back cover.
  4. Removing Minolta X-370 Bottom Cover: stap 4, afbeelding 1 van 1
    • Remove three 3.5mm screws.
    • Remove two 3.8mm screws.
    • Remove one 6.35mm screw.
    • Remove one 4mm screw. Lift off the disk.
    • Remove one 5.11mm screw.
  5. Removing Minolta X-370 Bottom Cover: stap 5, afbeelding 1 van 1
    • Lift up the silver, metal piece
    • Please note that some internal pieces may come loose during this process.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Nick
525 Reputatie
4 handleidingen geschreven
Cal Poly, Team 8-7, Regan Spring 2011 Lid van Cal Poly, Team 8-7, Regan Spring 2011
CPSU-REGAN-S11S8G7
4 Leden
8 handleidingen geschreven
Één opmerking
good advice, will use, have multiple Minolta cameras to work with.
gabriel johnson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 37
Altijd: 10,777
