Ga door naar hoofdinhoud
Removing HP Compaq dx2000MT CPU Cooler
Wat je nodig hebt
  1. Removing HP Compaq dx2000MT CPU Cooler, Removing the HP Compaq dx2000MT Case Doors: stap 1, afbeelding 1 van 1
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Removing HP Compaq dx2000MT CPU Cooler: stap 2, afbeelding 1 van 2 Removing HP Compaq dx2000MT CPU Cooler: stap 2, afbeelding 2 van 2
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Removing HP Compaq dx2000MT CPU Cooler: stap 3, afbeelding 1 van 3 Removing HP Compaq dx2000MT CPU Cooler: stap 3, afbeelding 2 van 3 Removing HP Compaq dx2000MT CPU Cooler: stap 3, afbeelding 3 van 3
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Removing HP Compaq dx2000MT CPU Cooler: stap 4, afbeelding 1 van 3 Removing HP Compaq dx2000MT CPU Cooler: stap 4, afbeelding 2 van 3 Removing HP Compaq dx2000MT CPU Cooler: stap 4, afbeelding 3 van 3
    • Once again, this may take considerable force.
  5. Removing HP Compaq dx2000MT CPU Cooler, Removing HP Compaq dx2000MT CPU Cooler: stap 5, afbeelding 1 van 2 Removing HP Compaq dx2000MT CPU Cooler, Removing HP Compaq dx2000MT CPU Cooler: stap 5, afbeelding 2 van 2
    • Remove the 3 pin power connector by pulling it towards the side of the device.
  6. Removing HP Compaq dx2000MT CPU Cooler: stap 6, afbeelding 1 van 2 Removing HP Compaq dx2000MT CPU Cooler: stap 6, afbeelding 2 van 2
    • Unscrew the 4 Torx T15 screws holding the CPU Cooler in place.
    • Make sure to hold your cpu cooler when removing the screws. You don't want it to fall!
  7. Removing HP Compaq dx2000MT CPU Cooler: stap 7, afbeelding 1 van 2 Removing HP Compaq dx2000MT CPU Cooler: stap 7, afbeelding 2 van 2
    • Remove the cpu cooler by pulling out towards the side of the device.
    • Make sure you do not touch where the cpu cooler makes contact with the processor! You could contaminate the layer of thermal paste that separates these components.
    • When replacing your cpu cooler, make sure you clean the processor contact area on the cooler and processor with isopropyl rubbing alcohol.
Conclusie
Logan Pace
2.251 Reputatie
9 handleidingen geschreven
Cal Poly, Team 17-16, Regan Fall 2011 Lid van Cal Poly, Team 17-16, Regan Fall 2011
CPSU-REGAN-F11S17G16
4 Leden
17 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 17
Altijd: 5,509
