Inleiding
Removing front panel to replace main LCD or small display screen.
Onderdelen
Geen onderdelen nodig.
  1. Using the plastic opening tool, pry off the top faceplate.
    • Using the plastic opening tool, pry off the top faceplate.
    • Place the tool in the small crack that runs along the side of the phone and pry.
  2. Using the T6 Torx Screwdriver remove all 4 small screws.
    • Using the T6 Torx Screwdriver remove all 4 small screws.
    • Remove silver plate from phone.
    • Using the spudger remove the plastic camera casing
    • Using the iPod Opening Tool remove the yellow flex cable from the green logic board.
    • Use Spudger or hands to detach flex cable from front screen logic board
Conclusie
Cecilia
1 Reputatie
3 handleidingen geschreven
Cal Poly, Team 27-96, Amido Spring 2010 Lid van Cal Poly, Team 27-96, Amido Spring 2010
CPSU-AMIDO-S10S27G96
4 Leden
15 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 1,802
