Ga door naar hoofdinhoud
Removing Fender Frontman 15r Back panel
Wat je nodig hebt
  1. Removing Fender Frontman 15r Back panel, Back panel: stap 1, afbeelding 1 van 1
    • Be sure to unplug the device before proceeding.
    • Use a Phillips #0 screwdriver to remove the four 21.7mm screws holding the back panel to the frame.
  2. Removing Fender Frontman 15r Back panel: stap 2, afbeelding 1 van 1
    • Once the screws are out, use a plastic opening tool or spudger to pry the top of the back panel open. There may be some resistance, but it will eventually pry loose.
  3. Removing Fender Frontman 15r Back panel: stap 3, afbeelding 1 van 1
    • Once the top is separated, use your hand to remove the back panel from the unit.
Conclusie
Greg Sawers
85 Reputatie
3 handleidingen geschreven
Cal Poly, Team 24-30, Regan Fall 2012 Lid van Cal Poly, Team 24-30, Regan Fall 2012
CPSU-REGAN-F12S24G30
5 Leden
7 handleidingen geschreven
Één opmerking
I need to know where to find a used circuit board for my Fender Frontman 15G. A circuit board from a Fender Frontman 15R will also work. Please help me.
sparkyman401 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 28
Altijd: 6,651
