Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
Use a spudger to remove the base cover from the rest of bottom cover.
Remove the three 5mm Phillips #0 screws that keep the battery connected to the computer.
Using the pull tab on the battery, lift the battery out of the computer.
The model device did not come with a hard drive. However, you will need to remove the hard drive to proceed. Please remove the hard drive following the steps on page 16 of the official Dell Inspiron 15-7537 manual.
Completely unscrew the 2 mm screw that connects the WiFi card to the mother board using a Philips head screwdriver.
Disconnect the two antennas (one black and one white) from the wireless card.
Remove the single 5mm screw that connects the keyboard to the palm assembly with the Phillips head screwdriver.
Flip over the computer and open the display as far as it can go.
Use the spudger to remove the keyboard from the palm assembly.
Gently flip over the keyboard and place it on the palm rest assembly.
Lift the connector latches and disconnect the keyboard and the keyboard back-light cables.
Unscrew the two black 5 mm screws underneath the keyboard using a Phillips head screwdriver.
Flip the computer and remove the two silver 5 mm screws on the corners of the base cover with the Phillips head screwdriver.
Unscrew the three black 5 mm screws with the Phillips head screwdriver.
Remove the three silver 2 mm screws (with large flat circular heads) from where the battery was taken out with the Phillips head screwdriver.
Place a plastic spudger underneath the base cover and move it along the outside of the cover. Once the cover is disconnected lift the off the base cover.
